ARGOMENTO: TENERONA CON PROBLEMI AVVIO QUANDO PIOVE
TENERONA CON PROBLEMI AVVIO QUANDO PIOVE 29/10/2008 14:05 #6714563
  • atro
  • Avatar di atro
ok, ok sono tranquillo so che con i vs consigli ne vengo fuori, ok.
allora, normalmente la mucca va in moto all'istante, cioè, aria tirata, chiave girata, apro rubinetti schiaccio trrrr.... vrooooooom, brum, brum e va in moto, tatatatatatatatatata, levo lo starter, un colpo di gas , vrroooooommmmmmmmmm - a posto :motoretta: vado fino in capo al mondo.
questo procedimento sempre, estate, inverno a meno 5 , autunno e primavera, sempre tranquillo.
ora..........
torno da figline moto ferma da 4 o 5 giorni ( LA MIA MOTO NON STA MAI SPENTA PER PIU DI UNA SETTIMANA la uso tutto l'anno), piove, vado dalla moto ....
faccio tutto il solito procedimento ma ... :shock: trrrrrrrrrrrrr , niente. Trrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr, niente TRrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr - tolgo lo starter . trrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr tic - tic- tic basta, batteria morta.
scrivo qui a voi, provo attaccare la batteria alla macchina, trrrrrrrrr tic- tic - tic ........ niente.
ormai rassegnato la spingo col mio babbo un pezzetto in salita ma proprio 40 metri di salita.
mi butto in discesa, butto la PRIMA per fare piu attrito..... booooooo......booooooooo..bbbbbbbbbboooooo...ttttt rrrrrr vrrrmmm ...vvroooooommmmmmmmmmmmmmmmmmmmmmmmm e parte, fa fumate nere ( ingolfatissima) ma va in moto, l'indomani ( non pioveva) la accendo alla prima come da procedura ordinaria.
ora, era da domenica sera che era sotto la tettoia, stamattina vado li, faccio tutto e mi fa una bella leva... niente.... La batteria ha avuto una normale autonomia , sembrava in forma, ma la moto non si accendeva, insomma girava bene ( so capire se la batteria è moscia o se spinge, raga vi giuro spinge), ma nulla.
ora, sicuro è qualcosa che si fa condizionare dalle situazioni meteo,
controllerò il cavo massa che dice luca , cavi pippette, candele, non so :nurse: :nurse: :nurse: :nurse:
Genoa, grande amore
TENERONA CON PROBLEMI AVVIO QUANDO PIOVE 29/10/2008 22:20 #6714661
come dice luca potrebbero essere i cavi delle candele che si sono invecchiati e allora scaricano a massa con l'umidita',poi controlla pure le candele e le pipette dai una bella pulita passa dello spray al silicone e vedi come va' ciao
TENERONA CON PROBLEMI AVVIO QUANDO PIOVE 29/10/2008 22:34 #6714670
Quelle astrali?? :mrgreen: :mrgreen:
Bello il tuo collegamento dei fari allo xeno :twisted: :censored: :moglie:
Per non parlare poi di quelli delle frecce :censored: :censored: :censored: :censored: :moglie: :moglie:
Luca :angle: :tentatore:
LUCA..LUCA...CHE HA COMBINATO????....DAI DAI FACCE VEDE'....CASTIGO PUBBLICO.....
TENERONA CON PROBLEMI AVVIO QUANDO PIOVE 30/10/2008 09:44 #6714760
  • atro
  • Avatar di atro
Buondi' raga, allora aggiornamento.....
ieri sera all'1 di notte dopo la gloriosa serata allo stadio, parcheggio l'auto e siccome avevo le chiavi della moto in tasca decido di provare ad accenderla.
:shock:
Parte al primo colpo e gira che è un orologio. :shock:
non ho altro da aggiungere signori della corte.
:book:
Genoa, grande amore
TENERONA CON PROBLEMI AVVIO QUANDO PIOVE 30/10/2008 09:46 #6714761
ON TOPIC PLEASEEEEEE
TENERONA CON PROBLEMI AVVIO QUANDO PIOVE 30/10/2008 10:56 #6714772
Altro , ti racconto una storia , accaduta a me , un giorno decido di montare la spia dell'olio con pressostato fiat uno( lavorando nel settore me lo sono costruito da me l'adattatore) siccome l'interuttore funziona staccando la massa decido di cercare un filo positivo e lo becco dentro il cruscotto dietro il contagiri.
Moto spenta giro la chiave spia dell'olio accesa vado per avviare , mi parte ma dopo aver insistito più del dovuto, mi dico , forse sarà che ho smontato i carburatori e che avevo le vaschette vuote, pasa del tempo e la cosa peggiora, a moto accesa tutto ok, solo un grosso problema avviarla.
Nel tempo che passava il problema rimaneva , se l'acendevo a spinta partiva subito se provavo con il motorino di avviamento ci voleva moltissimo tempo.
Vai dal mecca torna dal mecca e rivai dal mecca , soldi a palate e il problema rimane, ho cambiato bobine controllato il pikup, ne ho provate di tutti i colori, ho provato a collegare i cavi della macchina e il problema rimaneva, quasi non ci pensavo più alla spia dell'olio, un giorno mi si accende la lampadina nel cervello e comincio a dirmi che la voglio sistemare a tutti i costi, comincio con l'osservarla e fare varie prove , ogni giorno una diversa fino a quando mi dico ....a moto spenta ho luce neutral accesa e luce olio accesa...mi ripeto luce olio accesa, faccio una prova stacco la spia dell'olio, provo e la moto parte in un secondo di orologio , la ricollego e la moto non parte subito, provo a spinta parte subito riprovo con motorino non riparte, stacco la spia dell'olio un'altra volta e parte subito.
Sai che minkiata avevo fatto, ho preso un filo positivo controllando con una lampadina (filo grigio del ritorno del contagiri alla centralina) a luce spia olio accesa inviava il segnale sbagliato alla centralina perchè faceva da disturbo e la moto non partiva, ora l'ho spostato sul marrone e va che è una bomba.
Il mio consiglio visto che a spinta ti parte bene e con motorino di avviamento no, lo fa in condizioni di umidità controlla il filo grigio che va dal contagiri alla centralina , controlla il conettore della centralina, mi sembra di ricordare che la tua centralina ha l'involucro rotto e forse è proprio l'umidità, entrambi dalla descrizione abbiamo avuto lo stesso problema , sicuramente dovuto da fattori diversi ma l'imputato sono convinto sta tra contagiri e centralina., pulisci i faston , i conettori e fai attenzione controllando il filo grigio da dietro il contagiri.
Fa queste cose soltanto quando ti si presenta il problema e vedi se ti parte subito hai risolto.
Margi68 :ciao: :D
TENERONA CON PROBLEMI AVVIO QUANDO PIOVE 30/10/2008 11:17 #6714778
Reduce dal nubifragio di Roma di ieri sera ... anche la mia Tenerona ha qualche problema con l'acqua, nel senso che quando vado con pioggia forte presenta problemi nell'accensione (es. va a un cilindro) o quando la lavo con la lancia a pressione stenta ad avviarsi.
Candele che si bagnano?
M
TENERONA CON PROBLEMI AVVIO QUANDO PIOVE 30/10/2008 11:59 #6714781
  • atro
  • Avatar di atro
vero margie, la mia centralina ha dei tappulli........
ok controllero' quello che mi hai detto, belin dicevo, ieri alla prima è andata in moto...
boh..........
Genoa, grande amore
TENERONA CON PROBLEMI AVVIO QUANDO PIOVE 30/10/2008 13:27 #6714815
  • Ringraziamenti ricevuti 177
  • Tessera CTI n.: 0005
  • Tessera FMI n.: 19/300701/M
:shock:
:book:
Ripeto, metti una batteria chiusa 8) :wink:
TENERONA CON PROBLEMI AVVIO QUANDO PIOVE 30/10/2008 13:44 #6714821
  • atro
  • Avatar di atro
ok maci, ma per chiusa cosa intendi?
rivestita??
Genoa, grande amore
TENERONA CON PROBLEMI AVVIO QUANDO PIOVE 30/10/2008 13:53 #6714825
rivestita??
Quelle senza liquidi.....
Io ne ho su una (da 5 anni senza averla mai ricaricata e lasciando anche la moto ferma per molto) distribuita in italia dalla Hesa.....
TENERONA CON PROBLEMI AVVIO QUANDO PIOVE 30/10/2008 13:58 #6714828
  • atro
  • Avatar di atro
guarda un po c'entrano qualcosa queste?
www.groppo.it/catalogo/index.html?lang=it&target=d17.html
Genoa, grande amore
TENERONA CON PROBLEMI AVVIO QUANDO PIOVE 31/10/2008 19:32 #6715254
Sì, esattamente queste
Io con questa batteria ho risolto l'ultimo problema rimasto del SuperTénéré :banana: :banana:
TENERONA CON PROBLEMI AVVIO QUANDO PIOVE 08/11/2008 18:18 #6717110
  • atro
  • Avatar di atro
Ciao, scrivo per comunicarvi che alla fine ho risolto ieri i miei problemi di avviameno tenerona.
qualche giorno fa era capitato nuovamente che la moto non partiva fino ad arrivare in pochissimi tentativi alla morte definitiva della batteria.
Ieri ho montato una batteria nuova di zecca, è identica all'originale, non ho cercato quella speciale di cui parlava maci, cmq l'ho ritirata dopo che il tizio me l'ha preparata con acqua o acido e messa sotto carica.prezzo euro 52.00
Ovviamente la mia bambina adesso ne gode parecchio, non c'e pioggio nè freddo che la preoccupi.
oggi siamo usciti assieme dopo 10 gg di poggia, aveva le gomme molto sgonfie soprattutto l'anteriore, le ho gonfiate a 2 entrambe, è tutta un'altra storia ora è agile che sembra un cinquantino :mrgreen:
anzi un settecinquantino :clapping:
Genoa, grande amore
TENERONA CON PROBLEMI AVVIO QUANDO PIOVE 08/11/2008 18:22 #6717113
:mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen:
the president....aveva ragione......
